Cast iron vs. steel spindles
I notice in the current Rod & Custom magazine, that Heidt is advertising his 2" dropped Mustang II spindles and pointing out that his spindles are 1045 heat-treated steel, not iron. I thought iron is a better material for spindles. Iron has the correct metal properties. Maybe 1045 steel has the properties of iron but is, what, stronger?
PC - Here's the technical 411 (from my materials handbook): 1045 steel is a medium carbon cold or hot drawn utility steel. It has 43-50% carbon; can be hardened, tensile = 90-110 ksi; yield = 55-85 ksi. Not easily welded. Tougher to machine than hot rolled. Pretty strong stuff.
Cast iron, by comparison, has 1-7% carbon, a tensile of 60-70 ksi, and a yield of 40-50 ksi., is not hardenable, is weldable and easily machined.
Cast iron's main claim to fame for spindles is that it can be cast into the wierd shapes that spindles usually are and, if cast with thick enough sections, is plenty strong enough for the application, but will be heavier than 1045 to handle the same loads.
While 1045 steel is stronger by weight, cast iron is very tough stuff, absorbing shock reasonably well.
The bottom line is if I was rock crawling, I might want the 1045. If I'm just doing hard driving (including some rutted roads at speed) the cast iron is swell. 1045 is not a casting material, so the spindle has to be machined from a large blank of material. The cast iron is economical to cast at a near-net size.
I'll bet there's not a lot of similarity in the prices for these two parts.
There you go.
There you go.
blucollar4xford
24
12-10-2014 02:50 PM
GhstRdr
6.7L Power Stroke Diesel
17
06-20-2011 11:46 AM
