Brake Master Cylinder
Thanks for the reply Steve......this is after stopping the pedal keeps going down till you hit the floor, let up on the pedal and then re-apply and it goes to the floor slowly but none the less all the way down. The fluid has been changed once don't remember when, calipers are not sticking or leaking that I can tell. As I type this I had forgotten about the resevoir cap, I wonder if the seal in it is shot and it's letting air in the system. What about vacuum leak? I have got to find my service manual, I can't for the life of me remember what I did with it. 36 yrs old and already getting senior moments?
Thanks
John
Thanks
John
John -
My reply was based on fading, but it sounds like you definitely might have a master cylinder problem (check valve?). Have you tried pumping the pedal hard while someone checks all 4 corners for leaks.......just a thought? I've got 26 years on you, so I'm familiar with senior moments!!! Good luck on solving your problem.
Steve
Steve
obscurity
05-21-2013 08:49 PM
john19999
1997-2006 Expedition & Navigator
09-17-2012 08:10 PM
johns54
06-22-2002 09:28 PM
