new 9" vibrates
new 9" vibrates
I just installed a 72 f100 9" and now I have a vibration at 15 to 25 MPH.
I replaced the brakes, wheel bearings, installed a new drive shaft, reversed eye springs, short stacked the springs and installed new shocks.
That about covers how I messed it up, now how do I fix it.
BTW it now has a choppy ride - before it has just hard.
any help will cause great admiration.
Wheels and tires are known to be good I assume? After you read the article on Niolon's site and verify pinion angle, I would have the driveline shop have a quick look at the driveshaft. I believe you that they are reputable but mistakes can be made of course. I've had a slightly different experience than Paul regarding pinion angles. I accidently installed my 4* spacers in backwards briefly and can't really say I noticed a vibration. I think you can get by with a few degrees sometimes. But you certainly must be pretty close to correct.
I found the transmission shaft sitting at 0 degrees. (90 degrees from level)The differential, however, was setting at 8 degrees. (98 degrees from level) I got a set of 8 degree shims from a 4x4 shop and brought the diff to 0 degrees.
There is about a 3" rise in the drive shaft and that seems to be OK.
Again thanks a bunch.
