hey guys, i have a 1990 f150, it is 2wd with the 302 engine.
did those come with E4OD transmissions? or was it just the AOD? or both?
Is there a way to visually tell the 2 apart?
In 1990 I know the e40d was on the 5.8's I'm not sure on th 5.0. the E40D is a huge tranny has to be about 5 feet or more with 4 or 5 electical conections long the sides of the transmission.
to clear up the overdrive button issue the 1987-1991 trucks you had to select overdrive (even on a E40d transmission) on 1992-up for overdrive you just push the button on the shifter.
you are most likely right. I worked on a '90 f150 with an e40d and i think there is a overdrive switch on the dashboard around were the 4x4 button would be. My bad yall
