Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
boost bypass for my lightning
Old 08-02-2004, 10:31 PM
stevelacey75's Avatar
stevelacey75
stevelacey75 is offline
Question boost bypass for my lightning
if i run a boost bypass for my lightning will i still have a rev-limiter? should i rerun my pink wire or put on a new 3/16 hose? what are the ups and downs of doing this?
Old 08-03-2004, 12:14 AM
proflyer's Avatar
proflyer
proflyer is offline
Hmm, did it to my L and still can adjust the rev limiter through my predator tuner so I don't think it affects that function, could be wrong, but something kicks in when I set it because I was testing it one day and had it set to like 3000 rpm's and it wouldn't rev past that...
Old 08-17-2004, 12:24 AM
Blown00Ford's Avatar
Blown00Ford
Blown00Ford is offline
Boost Bypass will not affect your rev limiter at all. It is controlled by the computer and can only be adjusted or removed by a tuner or chip. As far as re running your pink line or getting a new hose, whatever suits your fancy. The ups are supposed to be that the bypass doesnt kick in and keep you from not having any boost, although I have never heard of anyone actually having this problem personally, I guess it does exist. If it has happened to someone, please post up, I'd like to hear it. I have this mod installed on my truck and have a 4# pulley and have never had any boost problems. The downs is that the mileage goes down a little bit. Never measured it and I am a leadfoot, but it seems to have lost a few MPG. That and I guess its not emissions legal. Other than that, I dont think there are any other downs. http://www.*********.com/boost%20bypass.htm
Check out the link for the part numbers and instructions needed for a boost bypass mod.
rock2610d
Modular V10 (6.8l)
05-10-2016 03:16 PM
rockrig4x4
05-07-2016 06:17 PM
El Camino Man
Modular V8 (4.6L, 5.4L)
05-13-2014 09:13 AM
Ron
08-29-2000 09:35 AM
Quick Reply: boost bypass for my lightning
