f350 4x4 starter always engaged
hello all new user here. my starter today stayed engaged even with key out ... what would be my best bet new switch or would something else do this : ) the starter was acting up the other day but not staying engaged but would spin and not engage and today stayed spinning any help would be great thxs guys
it is a 1987 f 350 4x4 crew cab i just got it a week ago thxs again
when i got the truck they said they had some wiring problems no headlights things of that nature lights a re working except reverse and back cab think it is a outside dome light but the soleniod does look new thxs for the info : ) i am willing to go get another and put it on looks eaiser then ignition switch : ) LOL thxs again : )
If the starter is running, the solenoid is engaged. Try unplugging the solenoid: there are three connections on the solenoid if I remember correctly, two heavy cables on the posts and a little wire plugged into it. Hook up your battery and then unplug that little wire. If the starter is still spinning, replace the solenoid, if not, it is an ignition switch problem.
I have put 2 starter solenoids in my 87 f150 and I am still having a problem with the solenoid sticking. I unhook the battery, and tap the solenoid and sometimes it will work fine, but most of the time the starter stays engaged, my battery voltage is good, my ground wires are good.Any suggestions?
Try reversing the wires on the relay. A lot of the aftermarket relays are build in reverse of the Ford relay.
