351c distributor upgrade
Old 07-24-2004, 11:55 PM
Cracker289's Avatar
Cracker289
Cracker289 is offline
Hi, I have a 351c out of a 73 cougar, and it's points type ignition. I would like to buy a new distributor that is electronic, is there a specifc year range I should ask for, like should I tell the parts counter kid that I want a distributor for a 1977 with a 400 engine or something? I know some of you are going to say get a Pertronix, but I want to replace this 30 year old distributor anyway and it seems like it makes more financial sense to upgrade to electronic ignition at the same time.
Old 07-25-2004, 01:40 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
I personally run the MSD dist but I am getting the impression that you don't want to go with an aftermarket dist so the 351c uses the same dist as the 351m/400, 429, and 460 so any of those with an electronic ignition will fit right in, just remember you will need an ignition box to go with it, so I would go to a wrecking yard, and find a vehicle with one of those engines, and electronic box, and take the whole thing so you can also get the wiring. otherwise I would buy a aftermarket dist, and box such as the msd and the 6a box.
Old 07-25-2004, 01:52 AM
Cracker289's Avatar
Cracker289
Ok thanks for the tip. I'll make a junkyard run on Monday!
jdhudall
12-24-2016 09:28 PM
351Cleveland C4
31
03-06-2016 05:38 PM
74 F350 SCS
03-30-2013 11:19 AM
eladnermai
11-23-2012 02:04 PM
EFM
19
04-13-2008 06:05 PM
Quick Reply: 351c distributor upgrade
