V10 Miss under load 1100-2000 RPM 122K Mi
I need some troubleshooting help. My 2000 V10 is starting to miss only under a load and between 1100 and 2000 RPM. The problem is worse during hot weather. I suspect a weak coil but I am not sure how to test them.
I changed the spark plugs at 105K Mi and all was ok. The problem started at 115K Mi and has steadily gotton worse.
2000 F250 V10 5-Speed 122K Mi, All Stock
Thanks in advance for any help you may have.
Dean
Dean
Before you spend the bucks on a new coil I would check the hose that goes from your PCV Valve to the Throttle Body. My truck was acting up and seemed like it was missing under load and sometimes just empty. Open up the hood to take a look with the engine running and you could hear the air coming from the trottle body. Moved the cover and you could see the crack in the elbow coming from the trottle body. Just replaced it last night and all is well.
