General Automotive Discussion
True Octane measurement
Old 07-21-2004, 02:13 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Kind of a dumb ? But how does the gov't or gas industry monitor or measure octane ?
Say at the pump it says 87,91,93 octane
Is there a Test engine or some tool to verify the octane they sell us???
I've heard of an engine that has a variable compression ratio with knock sensors on it ,that has a scale of octane predetermined on it
Does anybody Know ??????
Some of us who run snowmobiles in the backcountry would like to know?
Rich
Old 07-21-2004, 02:19 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
There are two laboratory tests to measure octane which are run in a single-cylinder engine operated under different conditions: Research Octane Number (RON) and Motor octane number (MON). The octane number posted on gasoline dispensers in service stations is the Antiknock Index (AKI) - the average of RON and MON [(RON + MON)/2, usually abbreviated (R + M)/2.
Do you weant to know who actually tests the fuel you buy or how the fuel is actually tested?
The engine briefly described above can indeed run a different compression ratios. The head is moveable up and down and can be adjusted while the engine is running.
Testing is done by the manufacturer.
Old 07-21-2004, 02:24 PM
mlf72f250's Avatar
mlf72f250
mlf72f250 is offline
Yes, as Monsta said so well there is standard hardware.
In the old days the oil companies had road octane test programs as well. But most automakers (except for Porsche, BMW, Cadillac and a few other high-end cars) don't care much about premium anymore, as long as regular is 87.
It's controlled pretty well by the refinieries.
And states with "weights and measures" departments have monitoring programs (at the stations) to keep them honest.
More here under octane number:
http://www.chevron.com/prodserv/fuel...esting/pg5.asp
FortyFords's Avatar
FortyFords
How the fuel is actually tested .Monsta
Hello! To the big Kahuna himself
Rich
Old 07-21-2004, 02:30 PM
FortyFords's Avatar
FortyFords
Thanks to both of you !
Rich
bendmac
Computer Chips & Tuners
07-13-2017 02:48 PM
brentkhack
2015 + Expedition & Navigator
16
11-12-2015 12:13 PM
89f350xlt
11-07-2015 06:43 PM
Cobra-Kai
13
04-01-2014 04:28 PM
ymeski56
41
08-13-2011 04:55 PM
Quick Reply: True Octane measurement
