I have a 93 F150 L6 4X4 automatic. Lately it has started shifting pretty hard from 1st to second gear. It happens most of the time, not always. Teh fluid is new, the filter is new. Does anyone have any insight as to what else I could check? Thanks for your help.
I do have the O.D. canceller on the shifter. I will read the service manual tonight to see how to capture the codes. At this point I have no idea how it is done. Thanks for the info.
There is a good chance you will pull a torque converter clutch code. A common E4OD problem and, surprisingly, a cause of hard shifting. Let us know what codes there are.
