which rivits do I need to drill out to remove the window rgulator motor on the drivers door of my 95 explorer? And any other tricks necessary for replacement
When I replaced the motor on a 94 Explorer there were three rivits. IWhen removing the motor from the bracket, watch out for the arm, it is spring loaded. Drill a small hole through the arm and bracket and bolt down, before removing the motor.
