anti-freeze & brakes
OK how about this one took my 04 screw in yesterday because I keep smelling anti-freeze in the cab, at the same yime tell them to check the front brakes because they squeel all the time. I get it back in the afternoon, they tell me there is no coolant leak or smell, but the front brakes were shot & they had to turn the rotors. I'm calling B S 7800 mile on a truck & the brakes are shot, what gives? Oh and over 20 years as a mechanic I still smell anti-freeze in the cab. Anyone else have this problem or am I out of my mind?
on
1 Post
-Matt
Funny you mention that I just noticed the smell for the first time at 5700 miles! I didn't notice it outside the truck when i got out to see if it was my truck or coming from someone elses vehicle. I don't have any leaks, but I know exactly what you mean about the heater core...That was my next thought! I have not noticed it since the one time, and it's been three or four days now.
I notice it too
Funny you should mention this about the anti-freeze smell. I get the same thing usually when I first get into the truck and for about the first 30 minutes then the smell seems to go away. I have asked my wife if she smells the same thing, but she says no. I still swear that I smell it which is a very noticable smell
No they did not charge for brakes, not sure how much they took off the rotors. Heater core is wht I thought also, I have seen them leak into the heater box from the bottom & pull the antifreeze back into the cooling system on cool down like a radiator does from the overflow, therefore it does not look like tou are losing coolant. Will definately be getting back with the dealer this week
I have experienced the same smell. Like you, I have spent years working on and around cars and the sweet smell of coolant/anti-freeze is not one you forget. In fact, I took mine back to the dealership the day after I bought it because I was sure there was a coolant leak. I watched them pump up the system with a tester and it held perfectly. The smell seems it like has gotten less noticeable over the last 6 months but I still catch a whiff of it every now and then. If you or anyone else finds an answer or solution to this problem, please post it.
Wondering if anybody STILL smells the antifreeze smell? My wife and I could smell it in our SuperCrew Lariat from day 1 and we have had the truck about 2 months now.
I marked the level of coolant in the overflow bottle to see if there has been any usage or leakage, but the level has remained about the same (notwithstanding what cruzer23 mentioned above).
Funny thing is, I don't really get the smell coming from the vents or from around the heater core/airbox area under the dash. Where the smell seems to come from is the grease used in the seat tracks!! The smell is VERY strong right in this area. Would any of you check your trucks and see if you think the same thing?
This "problem" is driving me nuts and I was ready to take the truck into the dealer, but I'm wondering if it is simply the grease. I can live with and/or fix that.
Thanks,
Mike
Thanks,
Mike
I still have the smell after 16k miles or so of ownership. Like you, I took it back to the dealer thinking it had a coolant leak. They pressure tested the system and determined that it wasn't leaking. I too noticed that the smell seems to originate from the seat grease. In fact, I think I posted that here several months ago. Whatever, I got used to the smell and it doesn't really annoy me anymore since I know that the cooling system is OK.
