Heater Core leaking?
Just in the last couple months I've been noticing radiator fluid puddling in my passenger's floormat, and it's continually getting worse. I would guess it to be the heater core leaking, but I'm not completely sure. I've taken the glove box out and the heater core cover off and the core fins are colored green.
Is this something I can fix myself with normal tools, or is there something special to do? I would guess that I just detach the two hoses under the hood then pull the core off and put the new one on?
One other question: Why does coolant run through the core when the heater is not turned on? Is it just part of the coolant flow loop?
Thanks all.
Thanks all.
Replacing the heater core was really simple. I did not replace the hoses (probably should have!) I did cut the very end of the hoses off where the clamp was so I could clamp down on a fresh place. One thing that struck me as funny is that the two hoses are different sizes! One of them fit the core pipe perfect, the other hose was about 1/8" larger on the inside and only fit loosly until I clamped it.
Yes, that's it. I did it on mine, but if you run air and it gets to be too cold it won't change because the heater supplies the little bit warmer air to be less cold, rather than the outside. As long as you have the standard heater, it is pretty easy to replace, I spent about 1/2 hour on it. If you have the high output heater, it's more involved. The way to tell the difference is by the placement of the core. If it passes through the firewall, you have the easy one. If it goes into the heater case, you have the harder one.
Felro86,
"The way to tell the difference is by the placement of the core. If it passes through the firewall, you have the easy one. If it goes into the heater case, you have the harder one."
Not sure how to dertemine which I have. I do have hose connections that are fixed into firewall and the heater hoses conect to them if thats what you mean. My truck is a '93 F150 XLT Super Cab, 5.0, Auto E4OD, 2wd.
Thanks,
Wes
Thanks,
Wes
Not sure which ones you guys have, but on most of the newer ones atleast the ones i have done from 97 and up vehicles, you have to remove the WHOLE dash to get to the heater core because there is no way in hell you can get it out with all the air ducts that are up underneath the dashes, once the whole dash is removed then you can take out the whole heater box and disassemble it. It only takes about 30-45min to get the whole dash off, really alot easier than it sounds. Its really cool how they have built the insides of the newer vehicles.
