'53 dashboard
Old 06-15-2004, 06:26 AM
jvmcc's Avatar
jvmcc
jvmcc is offline
Question '53 dashboard
I'm fixing up my truck. I'd like to do the dash as stock as possible. I am aware that a starter button was located on the dash in some (if not all) models. Mine's always started using the keyed ignition switch. Which way is stock?
Old 06-15-2004, 06:39 AM
barry's Avatar
barry
barry is offline
1955 was the last year for a starter push button switch. In 56 , they went to the present day style of starting a vehicle thru the ignition switch. So, to answer your question, yes, you should have a push button.
Barry
50 F-1
Old 06-15-2004, 06:44 AM
jvmcc's Avatar
jvmcc
jvmcc is offline
Thanks. Now, to do this dashboard up stock (or close to stock) should I just move the starter wire off the switch I have and run it over to the starter button, or can I find an ignition switch that doesn't have the capacity to engage tha starter?
Old 06-15-2004, 09:54 AM
Trader Bob's Avatar
Trader Bob
Trader Bob is offline
Hi, the start button just completes the circute after you have turned the key, stick with the stock switch and key. Bob
