Just turbo'd my 300 six
#241
Wow, i cant believe this thread is still going. I'v been watching it since it began.
I have dreamed of turbocharging my 300. I just need a few more reliable HP and TQ. I do alot of towing and it'd be nice. Im hoping to start collecting parts. I plan on using the MegaSquirt system unless you'v been able to reliably manage fuel using the existing computer. Even then i like the idea of being able to fine tune it easily. And being a computer guy it seems more fun to me. My 300 is in perfect working condition, so i think it would make a good amount of power.
TB:
How did you deal with the emissions stuff?
Would you mind giving some more close up pics of your build?
Thanks
TB:
Thanks
#243
#244
finaly done mine. its a 63mm turbonetics off of a CAT, carb is a 350 2 bbl. running water/methanol injection it hits a wall at about 14 psi. pulls like a cummins though. very very happy with it.
Picture007.jpg?t=1278894150
Picture014.jpg?t=1278894189
Picture016.jpg?t=1278894220
#245
#246
so i've got a 300 build i'm working on, already have a holley 390 4bbl, offy DP intake, and hooker headers.... obiviously if i decided to turbo i could kiss the headers goodbye unless i went with the rear mounted turbo idea... also going to run a 240 head with chevy 200 valves and rockers, along with 240 pushrods and a cam with .456 lift, should be slightly higher with the chevy rockers. bottom end is stock but only has about 30k on it. yall think it could handle my mods and say 5lbs of boost? am i aiming for the moon or is this possible?
#247
Ok I just picked up a 83 f250 with a 300 and a 4 spd it blew the cam out the side of the block, I'm now getting a 1990 300 with the harness and everything for $250 my question is how much boost can I run through it stock? I plan on using a intercooler and methanol injection, what should I do to the motor before I drop it in?
#248
#249
Ok, i have bin doing alot of research and i have come to a conclusion about the amount of boost you can push an inline 6 with all stock parts. At about 10 PSI you will start building to much pressure. I have a 95 300 with fuel injection, plan on adding turbo, I have a buddy who is a master automotive engineer and he did all the math and figured with stiffer valve springs, new push rods, and some head modifieing with methanol you can push roughly 18-22 psi and it shouldnt push it to the limit but you will be on a fine line depening on rebuild parts, quality, etc.
Anyone know of an aftermarket head for this motor? stock is to restrictive!
#250
The only head I know of is an AJ head it's aluminum and costs something like $7000 it has no water passages it's a race only part, I know there have been some made from other heads such as the 351c cut up and braised together, also I think the ls1 heads where used and some one said something about taking a 300 head horizontally and braising on another one for really tall ports
#251
So according to your friend that should leave a 19.5:1 effective comp ratio with a 8.8:1 static comp ratio and 18 psi boost, so if I have a 9.5:1 static comp ratio and still run 15 psi boost, ideally I'd like to run methanol injection while cruiseing even under the turbo, another thing is can I run a second set of fuel injectors and run the methanol through it, what can I power these with? Can I run a jumper wire off of the fuel injectors or will the ms controller be able to run them seperatly?
#252
As for your methanol injection, I do not see a reason to run seperate fuel injectors. They have kits with injectors that mount onto the motor pretty much where ever you can. Some areas are recommened over others. I like right ontop of the intake manifold. BEST bang for the money but you have to be able to control fuel to air mixture ratio and run a bit Leaner.
As for compression ratios, I have not really asked about the calculations. I trust he did them correctly. But an 8:8:1 ratio sounds XTREMELY ideal for this system. My friend hits a 9:5:1 now without methanol, puts 350hp and 450trq with some custom tuning, and alot of dyno time(he has time and money lol). Other than that let me know, currently i am concetrating on rebuilding my motor and doing ALOT of head work to free up all that resistance inside the motor. It is so constricted by the head its rediculous!
Forgot to add about rest of your questions... ok, I would not run a seperate jumper wire. fuel injectors are not ideal as they will use WAY MORE than needed. Thats like saying im gonna run 1/3 water, 1/3 fuel, 1/3 air. Granted you want to replace your access fuel with water, you want to keep AS MUCH AS POSSIBLE in the cylinder to combust properly for best ower output and than cooling through the water. The ms controller will not. Its primary function is to run your FUEL injectors. Now granted you could but you would use as much fuel as water which is not ideal. unless you controller had 2 channels and you could control them both. Totally up to you, but the kit im looking at getting custom for my truck comes with injectors, check valve, nozzels(injectors), tank tap, pump, and all hosing i need. My buddy knows a distributor so im gonna help them design a kit for our i6.
#253
The main reason I was looking at the multiport as an option for the methanol injection was I read a few other places it gave better distribution across all the cylinders, I emailed diytuners about what megasquirt to get, appaerntly there r 3 with tons of little add ons. And I don't think I'm really trying to replace the fuel with water, the way I was explained for a static comp ratio, I'm sure it gets altered for turbo apps, is 89 octane 8.9:1 comp 93 octane 9.3:1 comp, when u go over u have to start pulling th timing because of detonation, this is all the comp ratio after bleed down I believe, I want to run as much compression as possible so I can efficiently run unloaded under the turbo, I'm shooting for 1600 revs @ 65 mph, and when I have to tow I just run it up into the turbo to overcome the gears
#254
