Spark Plug Change on E-350/V10
Old 05-06-2011, 09:07 PM
EM1/SS(ret)'s Avatar
EM1/SS(ret)
EM1/SS(ret) is offline
And we are DONE! Purrs like a REALLY big kitten! No more SES light, still have ABS but thats sensors...Replaced all 10 plugs with autolite plats, didnt need to replace any coils, all their resistances checked sat against the numbers in the Haynes manual. Several of the plugs I pulled were way over gapped, and some of the coils seemed like the springs were stuck up in there and not making contact...
Anyway...10 plugs, a few new toys..er..tools.., PCV, EGR and DPFE...6 codes cleared.
I've decided I am going to let the dealership do the Headers...need the warranty.
Old 05-08-2011, 07:06 PM
Grems4ever's Avatar
Grems4ever
Grems4ever is offline
Congrats on the plug change!
I've had tech problems or I would have jumped in sooner....
Just be sure the coils are plugged in securely - I had #4 come loose while towing last fall.
Old 05-08-2011, 11:21 PM
Bbasso's Avatar
Bbasso
Bbasso is offline
I'm not looking forward to this... 50K to go
Old 05-09-2011, 07:18 AM
Grems4ever's Avatar
Grems4ever
Its not that bad. Just do your research before you start and don't get in a hurry when you're doing it and all will go well.
Old 05-09-2011, 02:20 PM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
How many miles on your current set of plugs? I wouldn't go past 50K before checking and/or replacing them in these motors.
Maybe I misunderstood something?
Old 05-10-2011, 07:15 PM
EM1/SS(ret)
Cue the sad cartoon music..
Well..
Changed the plugs and checked the coils...
Still shuddered a little bit, but I convinced myself it not a misfire, must be something loose...like the Exhaust manifold!! $630 later, manifold is on great, new gaskets, studs and bolts...and we're still shuddering..
I'm gonna have to say its a misfire..again..but no codes.
Can I get a list of possible suspects in order of probability..
These are the codes I pulled before I DC'd the battery..
p0171, p0401, p0303, p0304, p0308, p0354
Thanks.
Old 05-10-2011, 08:31 PM
Grems4ever's Avatar
Grems4ever
Well, 303, 304, & 308 are misfire codes on cylinders 3,4, and 8.
I suspect that you have some bad coils on there. Before you run out and buy coils, check the boots and springs to make sure you've got good contact between the coil and plug.
Old 07-25-2017, 09:41 AM
camaroracer's Avatar
camaroracer
camaroracer is offline
Smile v10 shudder
My shudder at lower speeds turned out to be the lock up trans converter. If you replaced spark plugs this might be something to check out.
Just a thought: Bob
pamante
Modular V10 (6.8l)
04-03-2017 12:06 PM
German Joe
1999 to 2016 Super Duty
23
02-08-2017 01:56 PM
pamante
Modular V10 (6.8l)
01-22-2017 08:37 PM
Rory428
Modular V10 (6.8l)
24
10-23-2016 03:33 PM
dcgayhart
Modular V10 (6.8l)
19
05-06-2016 09:22 AM
Quick Reply: Spark Plug Change on E-350/V10
