Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-11-2004, 06:22 PM
RangerNoob RangerNoob is offline
Garage is empty, add now
RangerNoob is starting off with a positive reputation.
Exclamation Please tell me if this convertion will work
I have a 1965 falcon ranchero, 289 with a 4 speed transmition. My dad crashed his 1982 mustang when he got it so he has a 302 5.0L with 900 miles on it! In the mustang was a 5 speed transmition. Just for kiks, i want to do a engin and transmition swap on my falcon. I want the 302 and 5 speed in it. I would be very grateful if any one could tell me if this idea/plan would work. Thanks guys
  #2 (permalink)
Old 06-11-2004, 10:35 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
you have all the pieces, it's just a matter of putting them all in the right place. is the mustang fuel injected or carbed? if it's FI you would need to get the in-tank pump from the mustang customized into the ranchero, and you might need a slight driveshaft length adjustment? sounds like a go to me, but what about the brakes!
  #3 (permalink)
Old 06-12-2004, 02:28 PM
brakes
I alredy have some nice 12" sloted roters for my brakes. Thanks for your input.
  #4 (permalink)
Old 07-09-2004, 02:25 PM
rodbender rodbender is offline
rodbender is starting off with a positive reputation.
Since it's an 82 it'll have a carb. You'll need to change a few things to fit it right. First is the oil pan, pick-up and dipstick. The mustang will be rear sump. Then when you go to change the dipstick, which is in the pan on the stang, you'll find no provision for it in your 82 timing cover. So, you'll need to change the timing cover. Caution is needed here to make sure that you don't have interference with your fuel pump eccentric and the timing cover. Early 289s had a different thickness of cam gear,when not matched correctly it will grind a hole in the back of the timing cover.
The transmission swap will require either modifications to the stock mount or use one for a early Mustang w/T-5 swap. Same for the shifter. Also fiberglass replicas of the trans bump are available. It'll work, just take your time. Have Fun
  #5 (permalink)
Old 07-13-2004, 02:00 PM
I may have made an error. The trans mount for a V-8 in 63 Ranchero/Falcon is not even close to a 65 Mustang mount. The 63 has a leaf spring in it. I'm not familiar with the 64-65 Falcon trans mounts. The 63 V-8 engine mounts are identical to the early 65 Mustang. I know that to be a fact. Sorry for any inconvenience.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
