96 powerstroke from E4OD to 6 speed manual
Computer should be OK.I installed Bauman computer to control my e4,so my tranny is not connected to trucks PCM anymore.Had to put some resistors on the wire that went to the trans. range switch to "tell" the PCM the tranny was in N to start and D when running so that cruise control would work.The res. are on a relay to toggle on start and run off of ignition switch.Man, that 1st post is old!
Originally Posted by 1997F-350
dont know where you live but there was a couple guys(at tds) interested in the opposite of you a while back and were looking for someone to do a complete swap with.
The only thing I could think of that would be better, for me, would be a 6-speed. But there's always that money thing...
6 six woilf be a lot nicer but the 5 is a good trany too. I'm in the same boat you are I can't wait to ge the E4OD out of my truck and put in a manual.. fromwhat I've picked up the zf5 is by far the easier swap.. the zf6 takes some moving of crossmembers and you willl need a new transfer case to go with it. because of the spline..
Now if you get the zf5 out of the gassser afew things you want to think about.
What is yourer trucks axil gearing?? the gas tranys are gear much lower in 1st 2nd and 3rd. and the same in 4th and 5th.. so if you have a 4.10 you will basicly end up with a 4sp with a compound low.. that you will seldom use. but if you have a 3.55.. it seems like a realy good set up... youe 1sh-3rd wil be geared like a disely trany with a 4.10 and 4th aand 5th will run out welll onthe high way. Are the 351 and the460 the same bell houseing?? good luck J
wycowboy I have seen you post alot on this subject on diffent post and whatnot from what i have reseached if i get a deisel zf5 the bellhousing and t case will bolt up. i can get a flywheel, clutch throwout bearing and a clutch pedal out of a junk yard. but what about the clutch linkage. how will that work out.
thanks
Rusty
thanks
Rusty
From the people Ive talked to the best blas to get the master ans slave cylinders is new fron an auto parts store that way you can get the lines too. .. I found some good sourse for zf5's too if you go to junkyard dog ,com you will get tons of emails of used and re builds if thatdose not work I can pm you some good links. If I were you I would get a new fly wheel and south bend or luk clutch no reason to start with worn out parts. that will be the first to go. and then you can get a single mass fly wheel.. not the cheepest but I think it is what I wil do... Your truck wlll have a hole i n the fire wall for the master cylinder. it is just coverd by patch same with the shifter hole .. als keep me informed about any thing that you find out..I'm still gathering infomy self J
yeah i had plan on a single mass flywheel and diffently a south bend clutch. i figgure i will start mine in jan. after tax return check. after i get my fuel and oil leaks fixed but thats another post. I will keep you guys in touch. please do the same for me. I would love to talk to someone that has done it.
Rusty
Rusty
Hey Guys,
I have done a similar swap. I took out an e4od in my 90 F-350. I put in a ZF 6-speed. I also took out the IDI and put in a Powerstroke.
Info for you. I think the T-case input for the manual and the auto are different, so even if you go with the 5speed Ithink you will have to change t-cases. I bought all of mine together from a salvage yard. ZF-6, T-case, Drive Shafts, Pedal and Clutch linkage all together from the same truck. (I got the motor from a 99 E-350 ambulance)
I also got the cross member. I had to do a lot of fabricating on the cross member (it was from a 01 f-350 and the frames are slightly different.)
Hope that helps,
Craig
Hope that helps,
Craig
