99 Ford van 4.2 egr valve
Hope someone can help.
I changed the plugs on my 99 e150. Right after this I got a bad shake or miss in the motor when you apply just a little wee bit of gas. when you give a little more gas the shake goes away and when it Idles its ok too. Ten minutes after the plugs went in my check engine light came on. Plugs are not the problem.
I have put in new wires and new plugs again. The miss or shake is still there when you give just a wee bit of gas peddal.e. Engine light is still on. A mechanic
made the problem go away temporarily, he unpluged something to do with the egr valve while it was shaking and the problem went away momentarily. Came right back though. He said I need a new egr valve and solonoid. I then went to an emmisions place and they hooked up that code getting thing and said that it was my Throttle position sensor.
I dont know who to beleive. Are these code plug in things accurate.
nhredneck
2004 - 2008 F150
02-03-2018 11:39 AM
entropyjones
34
10-06-2014 03:03 PM
Redneckfordf2502002
1997-2006 Expedition & Navigator
08-12-2014 10:22 PM
