1977 with a 351 what's this mean on the engine?
Old 05-12-2004, 04:32 PM
rbastedo's Avatar
rbastedo
rbastedo is offline
1977 with a 351 what's this mean on the engine code?
I looked at the engine, it says on a sticker there it has a 351W "C" - I assume this is a 351 Windsor but what's the "C" there for?
Old 05-15-2004, 01:22 PM
clarko's Avatar
clarko
clarko is offline
It could be the engine code. For example, the 1965 Mustang's code for a 2V 289 is C.
Old 05-20-2004, 07:02 AM
ranchero77's Avatar
ranchero77
ranchero77 is offline
the windsor code is H. maybe its code for california emission. is the sticker on the engine?
Old 05-20-2004, 12:17 PM
ROSCO's Avatar
ROSCO
ROSCO is offline
If the radiator grill has a badge on it that looks like a gear then I think the "C" stands for Cleveland
Old 05-20-2004, 02:49 PM
ranchero77's Avatar
ranchero77
the cleavland wasn't an option for that year. not in the U.S anyaway
rbastedo, you should give us somemore info. are you sure its the stock engine? you checked the vin #
Old 06-08-2004, 07:23 PM
Damien's Avatar
Damien
Damien is offline
Here is a bit of information regarding the 351M/400:
"...Beginning in 1977 Ford decided to offer the newer 351M/400 engines in its place. Again, Ford could have used the smaller 302/351 Windsor engine since it was being offered in the F-100, however, it was decided that since all F-150, F-250, and F-350 trucks were equipped with the heavy duty 390 in the 2wd trucks and the 360 in the 4x4 trucks that the torque laden 351M/400 would make an excellent replacement. The “M”, by the way, does not stand for anything. Ford only used the “M” designation to distinguish it from the 351 W (Windsor) and the now discontinued 351C (Cleveland). The “M” designation has now become know to mean “modified” or “Michigan”, even though the 351M was produced at both the Cleveland foundry and Michigan casting center..."
More info can be found here:
http://www.projectbronco.com/History..._ford_351m.htm
Basically the motor you have is a 351M/400, which was originally a 351C. The 351C was discontinued / redesigned into the 351M/400, which can was can be either a 351 or 400 cid. Hope that helps some.
Old 06-08-2004, 07:58 PM
rbastedo's Avatar
rbastedo
rbastedo is offline
Weird, of course that's just something on a lable on a valve cover.
I guess I should find some identification on the engine to be sure.
Anyone know where to look on this thing?
oddfordjunkie
01-13-2013 11:43 PM
c_cort
31
04-10-2008 01:41 PM
hotbbb
03-20-2004 09:54 AM
travis c
08-13-2003 07:52 PM
canadianfordman
01-22-2001 12:40 AM
Quick Reply: 1977 with a 351 what's this mean on the engine?
