extended radius arm help
I need help, I have a 76 f150 im currently working on putting a 14'' suspension lift under it and a coil sprung dana 60 . The ? is with the radius arms being that caster will be set up with the dana 44 wedges at 4 degrese. would it be better to buy the extended radius arms (jeffs bronco graveyard) or make my own drop brackets. im not really concerned with flex but with that much lift i dont want anything binding up? any suggestions thanks.
right now i have stock radius arms that im going to make longer. but at the moment i have 9 inch on my truck and i used 6 inch drop brackets out of a super lift kit for a 78-79 f150.right now i have no binding. but after i get the new springs in ill have to relocate every thingim still trying to find all the parts i need
Maybe it is just me, but, I hate using drop brackets on radius arms so I do not. At the worse you get hung up or high centered on them, at the best they do not look right, and they break or rip the frame if they do not have the proper backing. I do like the looks of the James Duff "new" radius arm brackets that have 3 settings in them that go along with the extended radius arms.
with those extensions there is not enough metal to make them strong enough from bending. you can see them in this picture.
in the link below you can see the ones I made for my 78. The Dom tube extended them about 10 inches and they have huge 1-1/4 heim joints on the ends. The radius arms were filled in for about 6 inches where the DOM fit over the stock "I" beam part of the radius arm. I welded a huge nut on the end of the stock threads, then welded that to the DOM, then put a second nut in there welded to the inside of the DOM as well as the stock radius arm threads. Then the weld in bung went on the end of the DOM. The DOM it's self is .25 wall and the ID I think was like 2". I also put 1/4" plate on both sides od the arms to further add more strength to them.
http://www.1ton4x4.com/60mounting/
