car vs truck
Two main reasons, DOHC, and power to weight ratio.
Example: 94+ Integra GSR, 1.8L, I4 DOHC, 170hp. The car weights around 2700lbs, and revs to 8000rpm stock.
Ford 2.3L, I4 (single cam, either OHV, or SOHC) rated around 140-150hp in any Ranger (my 88' weights 3200+lbs) revs to maybe 6000rpm.
In general a DOHC engine is higher hp at higher rpm, and lower tq at lower rpm, than a single cam engine. This is also the reason why you can find Integras with some bolt ons and/or good driver that will walk on a stock 5.0 in the 1/4.
EDIT - Oh, and did I mention not to try this at home, but I have hit the top of the speedo in my Integra (145mph)
Yes, the 2.3L and the 2.5L are severly underpowered engines. Another thing to keep in mind, those little front wheel drive cars don't have nearly as much drivetrain to turn. Our trucks have to move our larger trannies, our long and heavy driveshaft, and then finally gets to the axles. Not only do our engines suck, but our truck's design sucks the power away from it.
its not really the design at fault....
its more of the nature of the vehicle at fault....
i dont know one single truck thats a fwd truck..
the fact that your ranger doesnt beat a car isnt the fault of ford... youd be hardpressed to find any truck from the factory, besides ones that are meant to be street trucks (like the ranger thunderbolt...) that will beat a car
theeeeeeen, the ranger motor isnt even designed for speed.... you could slap some new gears in it to make it go a little faster, but the fact is, its meant to be a truck, its limited at under 100mph.... its a truck...
now go load a civic with 2000lbs of wood, and load your truck with that, and see who wins that battle...
you bought a truck... go tow something, or go muddin'
Edit:
A few years back, I saw a fwd conversion in Truckin'. It was a Chevy 1500 with a Cadillac Northstar powertrain in it.
