FE block cyl. bore sizes, comments?
Well, got the 360 torn down and miced the cyl bores. At the top where I ran the ridge reamer they run from 4.088 to 4.091, miced at 3-9 and 12-6. Midpoint of the wear pattern they are from 4.0835 to 4.0845, at the lower end of the wear pattern they mic from 4.0835 to 4.085. Below the wear pattern at the bottom of the bore they mic from 4.0825 to 4.084. All bores seem to be pretty round and consistent. Pistons mic a consitent 4.076 to 4.077 on the skirt midway below the rings My question, overbore .060? Is that ok for this block and if so how hard is it to find the 390 rods and pistons/rings for this size bore and +.060? Looking for your comments as you guys have seena LOT more of these then I have. By the way I ordered the big block book you guys recommend, through the site. Still not here so I emailed them and after 3 days got a reply that it was back ordered.
Sorry this was sooooo long but I need to make some decisions. Thanks guys
jlj6t
77
03-13-2021 08:44 PM
piperig78
12-11-2013 11:14 PM
Oldyeller75
03-15-2011 10:20 AM
Ranger GT2
12-16-2005 03:24 PM
