292 Carb Help Needed Bad!
GUYS,
I have a 1958 Ford F100. It has a 292 with a Holley 2 Barrell. I got the timing set on the money and she idles pretty sound. The problem is when I go to stop at a stop sign she dies on me. I have to choke her up again to get it to start. NEED HELP BAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! Thanks
Originally Posted by Bugg58
GUYS,
Bugg58, i am Janet, and here is a post i made in another section, the place that describes the fuel filter type and location may help u, its from an answer i gave to another user, but you may find the information helpfull if you read it
"Hello, from the way you have described it, it sounds like fuel starvation. Many times i have seen where people will put a fuel filter between the fuel pump and carburetor...Guess what happens??? The fuel force actually crushes the inner element (even on clear see through filters that you cannot see with your eyes) and wala!@!!! Fuel can't get through during times of acceleration or when you hold a steady speed or will idle down gradually.. Be sure your fuel filter is the BIG ONE, and place it not between the pump and carb, but instead between the Tank and Pump (The suction non force side), that one error issue drives many people nuts because they change the fuel filter and get out and look and the flow is just dandy, but as pressure increases or idle continues it slowing gets less flow because of pressure forced element inside the filter because the filter is on the pressure side... Check that out, I fixed one at our shop about 3 years ago and a guy thought he needed a whole new ignition and tried this gauge and that reading and this and brought it to us, next day he nervously said, about what will this cost?? And i said 32 dollars hon, talk about a funny thing. I hope this helps you.....Janet"
Janet,
Thank you for your reply. I have the fuel filter mounted between the tank and the pump, so I guess that wouldn't be it. It wants to do it real bad on a slight downhill right before I go to stop. I have a manual tranny and as I slow down and push in the clutch it happens.
Thanks
Ray
Thanks
Ray
Janet,
Thanks
Ray
Thanks
Ray
Next thing would be primary wiring, coil , points, condensor...I assume you've checked these. Check the condition of your distrubitor inside the cap for corroded post, make sure the rotor is clean and up to par, now take two aspirins and call me???? Nah, try all and not the aspirins, good luck on it Ray
carb
Bugg, I used a large cannister style Fram filter. It is the one with a mounting bracket already attached to it, and is probably close to 3 inches in diameter. No threaded fittings on either end, and easy to mount. Most auto stores and Walmart carry it. It should last a lot longer than one of the clear ones.
Carb Problems
Some of the old holleys had a fine screen on the fuel inlet, might be clogged,
also you might want to check the needle and seat some had ascreen there as well. You might have dirt clogging one of your jets. Idle air bleeds probably need cleaned . Just some things to check.
GOOD LUCK!!!!! HOTWRENCH
I had the same sort of problem a while back, especially when getting off of a highway ramp. I got all sorts of advice about how to get rid of it. Here are some:
1. Has your fuel tank been cleaned of rust? Could have that in it, being picked up and brought into the filter/carb.
2. Does your fuel line run right against the block? Could be heating it up too much. I just put a conduit around the line with aluminum foil in it to insulate it.
3. I changed everything. Points, wires, plugs, condensor, cap, fuel filter. Even the antifreeze.
The problem went away after all that.
Some told me to just rebuild the carb.
It seems odd that this would just start happening at once.
What do your plugs look like? Sooty, clean as new?
This is simple, but is there a chance your idle is set a little low? What does it normally idle at? Is it smooth?
Where are your idle screws set at now?
Just my experience.
Just my experience.
Just my experience.
Just my experience.
My two cents. I think 81 and Janet may be on the money. It is very possible that the idle mixture screws were good, or on the lean side during cold weather, and you didn't have this problem.
Once the outside temperature warmed up, your carburetor is just too lean and won't idle without a readjustment.
