Manual transmission shifts very hard when first start up
Hi,
Newbie here. I'm not very knowledgeable in transmissions.
I have an 87 F150 with a manual 4 speed transmission. The transmission is the 4 speed with a very low first gear and I normally use second gear to start unless fully loaded.
I just had the transmission fluid changed and now when the truck is first started, it is very hard to shift out of second and third sometimes has a grinding type of feel through the shift stick (almost like two gears grinding against each other but not noisily, just in the feel through the shift stick). This seems to lessen as I drive. I guess because the transmission fluid heats up. Sometimes, I almost cannot get out of second!
Before I had the fluid changed I could shift like a hot knife through butter. I'm not sure what the garage used for the fluid replacement but I can find out.
Any ideas as to what is up?
It sounds like they used GL-5 rear axle fluid, maybe with the limited slip friction modifier additive included. That stuff is really not intended for transmissions because the syncros dont work well with EP or FM additives, causing grinding or reluctance to shift.
If that transmission was intended for ATF, that is an easy fix. If the spec is for 80W-90 GL-4 fluid, that can be a little hard to find. Redline MT-90 would be ideal in that case.
Jim
Jim
I went to my local Walmart and all they had was GL-5 spec. I called the local Pennzoil supplier and all they had was GL-5 spec. I thought I had found some Penzzoil but they did not have any gL-4. I'm in Massachusetts and most suppliers do not have the GL-4 gear lubes. I tried Auto Zone also and all they had was GL-5. I'll keep calling around but I don't have very high hopes.
Thanks for your input, it is appreciated.
Maybe try a farm supply store? That's amazing...I've never had trouble finding GL-4, though I never buy it cause I just steal my grandpa's. O_O No I don't steal it..he does it for me lol. Last time I filled the tranny I got oil all over his cardboard on his garage floor...he won' tbe letting me do it next time.
Question
Is the T18/T19 BW transmission 'rugged' enough to accept engine oil instead? I've heard of people running 10W40 in their M5OD transmissions...and the M5OD isn't nearly as stout as the T18 nad also calls for bloody ATF....what about running engine oil in the T18?
It all comes down to the synchro's, doesn't it?
Ive been having the almost same problem as rsampson as of late. The only difference is my trans shifts okay when its cool outside or when I first start driving her for the day, but then when I get about 3 miles down the road and/or when it gets up to operating temp then it dosent want to shift - it dosent want to come out of gear or go into the next gear or the lower gear. Some times I have to pump the clutch a few times to get it to shift.
Sometimes it'll be smooth and shift nomraly and other times the pedal will be super stiff, a lot more so then usual, and I'll have to pump it a few times to get it to want to shift, with relunctance. I've tried bleading the clutch and replaced the fluid in the clutch system and it still does it.
I'm running 80W-90 GL-5 spec in it now. Thats what ive always ran in it and no problem... till now. It is the stock trans. I beleave the same one thats been in scence it rolled off the factory floor in '84. The tag on my manual trans is:
C2604877
RTS AH CE22
34TRHA 0218
I beleave that that translates to a T170FT RTS 4 speed overdrive trans. Maybe theres something wrong with the preuusure plate? or maybe the clutch is just gone (I got throught clutches like non other).
Any ideas?
C2604877
RTS AH CE22
34TRHA 0218
Any ideas?
hayden01, I'd start looking at the clutch system for your problem. But first, have you checked the level of the oil? Maybe its low and has issues when it gets warm. Other than that, it sounds more like a clutch related issue. Like its not releasing properly. The throwout bearing could be sticking on the quill if thats the kind of setup it is. (quill is the tube that sticks out of the tranny that the input shaft is in, and the throwout bearing rides on)
ha ha so I uh found what the problem was - why my manual trans was not shifting or was hard to shift: the throwout betting went "poof"!! As in the bearings in the throwout barring its self went poof, decinigrated, burned up, turned to dust (literally)....in turn it chewed up the quill fairly good. But other then that the clutch disk its self is good and still has life left on it along with the pressure plate and the flywheel.
Does anybody know were to get an replacement quill? I put in my C6 that I had in the garage and already I miss my 4spd.
