1964 F750 brakes?
Old 05-17-2004, 10:34 AM
Al_V's Avatar
Al_V
Al_V is offline
Question 1964 F750 brakes?
I have noticed a few of you mentioning F500's, 600's, and so on. I have a 64 F750, and it looks like I may have a rear wheel cylinder leaking. How do you get the drum off? Do you have to pull the axle shaft out of the differential to get the hub off, and are the 5 nuts between the hub "spokes" holding the drum on? Looks like allot of work, any and all info is appreciated!
P.S. I think I have the Eaton 2-speed rear axle.
Old 05-18-2004, 12:43 PM
JSMConstruction's Avatar
JSMConstruction
JSMConstruction is offline
Talking
I have a 65 F-700 but i haven't dug into the brake system yet...
Old 05-18-2004, 05:20 PM
Al_V's Avatar
Al_V
Al_V is offline
Thanks anyway for replying, I think the brake system on these may be a weak point. Mine is a single reservoir system with a vacuum booster mounted on the frame under the driver's seat.
It looks like you do have to pull the axle shaft out of the rear axle to get the rear hub and brake drum off..... More work...........
thalvorson
11-08-2016 11:53 AM
Dr. Driveway
02-10-2016 06:21 PM
fordtruckguy98
Large Truck
01-17-2016 02:09 PM
Blue and White
11-17-2015 05:52 PM
Thomas66F750
Large Truck
08-20-2015 04:40 PM
Quick Reply: 1964 F750 brakes?
