35 in Tires
35 in Tires
Does anyone know what standard 35 in tire size will fit my 04 F150 with a 2.5 in Daystar kit. I have the BFG 285/70/17's which look great but they look like the tires that should have come from the factory not a bigger beefier tire. I just want to know what the biggest and cheapest tire size is.
I have driven daily plus wheeled hard with 315/70R17 (34.5") BFG AT tires with "our" ProtechEZLift 2.0, 2.5, 2.75 and currently have our 3.0" kit installed. No problems with tires rubbing even with the 2.0" lift.
The recommended wheel width is just that "recommended" nothing bad is going to happen if you go a little narrower or wider than the recommended. I would always go narrow if anything as it actually makes the tire a little taller and the wheel is less likely to get damaged plus less likely to have the tire come off the bead when aired down off road.
Just my $.02
Take Care,
Brian at www.ProtechEZLift.com
Just my $.02
Take Care,
since I have the Daystar kit, this is obviously an unsolicted comment:
check out Brian's web site link. www.ProtechEZLift.com
go to "our rides" and check out the 04 F150.
These are GREAT pictures and really looks like a GREAT product.
Originally Posted by Bigdawgs04
2.5 inch Daystar kit. I will hopefully have pix in my gallery this week. Just haven't had time to do it yet!
Thanks for the reply bidawgs
