Lamp Outage Module
Lamp Outage Module
Hi, I have a 96 explorer and the lights won't come one but the tail lamps works. basically it all works but the lamps themselves won't come on unless I pull the high beam switch towards me (so i have to drive holding the level towards me with highbeams). Someone suggested that something called the lamp outage module controls the current going to the lights and if this is faulty then the lamps won't come on and the computer won't pick up any headlamp problems. Does anyone know where this module is located so I can take a look at it and see if there are any loose connections, etc.
Thanks
Thanks
Well first off, unless you have a message center in the console, you dont have a LOM. If you have a message center then yes it could be related to the LOM. But usually it does quirky things like only one headlamp works. I would trace the circuit from the fusebox to the headlamp switch to the multifunction switch and out from there first.
Lamp Outage Module
Gemini19th81, I know this post is incredibly old... but to answer your question, Yes, your problem is the Lamp Outage Module. I too have a 1996 Explorer (Limited) and had the exact problem. And in fact, if you do a little research online, you'll notice that HUNDREDS of other explorer owners have been having the same problem too.
The L.O.M. is located directly beneath the message center. You can just pop off the message center screen by squeezing the sides. The cup holder comes off the same way. The Lamp Out Module should be on the passenger side of the console, about where the passengers knee would be. It's got a bunch of wires plugged into one side, it's about the size of a pack of cigarettes, held on by 2 screws. Once you have it removed, you can open it up. there's a few clips keeping it closed, it can be kinda tricky. When you get it open, you should be able to clearly see a burned area around a few of the resistors.
If you want to save yourself $300, you can just use a soldering gun to touch up the burnt contacts, or take it to an electronics shop. I'm sure they wouldn't even charge you for something so simple. Ford should have recalled this years ago. I hope this helps.
brokersteve
01-16-2017 11:39 AM
Cummins7mm
04-22-2016 11:07 AM
