New Driveline Parts Number
Hi All,
I was PM'd this morning from one of my "sources" stating that Ford has had new (replacement) drivelines manufactured, the units are starting to ship end of this week for those of us with vibration complaints. The new drivelines carry a different part number from those previously installed on 2004 F150 trucks.
Can anyone comfirm this?
I hope so, maybe now my truck will become usable.
Originally Posted by bigplayrayr
Does your truck still have the vibration when you put it in neutral? Mine still does, does that eleiminate the driveshaft from being a problem?
Forgive my mechanical ineptness, but even you are going down the road and you put the truck in neutral, doesn't the drive shaft still rotate?
This does sound like good news...!!!!
Originally Posted by newtof150
Hi All,
To be honest I'm not quite sure. I would think the transmission would stop spinning it, but it might turn with the rear differential. Mr Goodwrench I'm not either.
If your REAR wheels are turning.....so is your drive shaft!!
It doesn't matter if the engine is on or off....or if the transmission is in drive or neutral.....the rotating left and right axles will turn the drive shaft through the main gears in the rear differential, as they are MECHANICLLY "connected".
triton-ic......
I completely understood what you were saying in your previous post!! And I agree with you....that to REALLY find the which drivetrain component is vibrating.....you MUST isolate EACH INDIVIDUAL drivetrain component, and check it BY ITSELF.
I was simply answering bigplayrayr's earlier question/post with a little more explanation than you offered.
This is not making much sense to me, If you put it in neutral and it goes away, all that really tells me is the drive train has to be under a load to vibrate, I dont see where it eliminates anything but the tires (maybe), towing the truck with the back wheels off the ground and running the engine, Im assuming in neutral, can be done just as easy by sitting in neutral and running the engine up to the rpm where the vibration is felt. If you are towing the vehicle it still may be a front tire vib, or the half shafts, hubs etc. or even a frame vib since the front tires are still moving. The only way to trully eliminate any component is to replace it and drive the truck under the same conditions. This is why it is so hard to find this problem! Ford is going to have to take two trucks one vibrator and one good one and swap parts until they find the culprit!!
