K&N vs. Kool Blue
Originally Posted by ga302p
All the numbers I have seen show the cloth filters catch smaller particles than the paper, when the cloth filter is PROPERLY OILED. If they are not oiled enough, they will let some pretty large stuff through.
Originally Posted by Bob Ayers
Not true, K&N now offers a "precharger" filter to use with their regular filter in dusty conditions. The OEM paper filter will filter out smaller dirt particles.....
I am not exactly sure what the precharger is, I know what the K&N "pre filter" is.
"Now that you have our filter would you like to buy a filter for it?"
or
"Now that you have our filtercharger, would you like a precharger?"
Version A makes it sound like the filter isn't good enough.
Version B makes it sound like the added filtering will increase power.
They have four prefilters that I've seen.
The precharger is a polyester wrap.
The airforce precleaner is a foam wrap.
The wetsuit is a silicone treated foam wrap.
The drycharger is a silicone treated polyester wrap.
The silicone treatment is for repelling water in marine applications.
They catch the larger particles and keep the actual filter cleaner to keep its flow up.
At least that's the spin they put on it.
Originally Posted by K&N Instructions
CAUTION:
Extreme fine dust in agriculture or off-road use will pull the oil
from the element. Frequent re-oiling of the element's clean side might be required.
I have not used a Kool Blue filter before but i do know one thing that you can probably find this cheaper than the KN...performance wise i put an KN on my 360 and i instantly felt a better throttle response i don't know about power but i could tell the difference instanty over the paper filter it replaced
tilopa
13
09-21-2014 09:50 PM
durk
04-08-2006 03:54 PM
