Spark Plug Gap
Old 05-07-2004, 11:33 AM
bent rim's Avatar
bent rim
bent rim is offline
Spark Plug Gap
Just wondering how critical gapping new plugs are vs installing straight out of the box in regards to power and mpg's.
Old 05-07-2004, 11:49 AM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Very, you need the correct gap.
Old 05-07-2004, 01:06 PM
acerockola77's Avatar
acerockola77
acerockola77 is offline
Most of the time the plugs that I get already are set to the correct gap (well the specified gap for the truck).
Old 05-07-2004, 01:16 PM
Slade901's Avatar
Slade901
Slade901 is offline
I used to take the word of part clerk and telling me that it is already gapped to the right specs for my vehicle.
One day I checked the gap just to make sure and not all of them have the same gap and I have to adjust it myself.
Everytime I order spark plugs, I always tell them to write the gap specs on the side of the spark plug box and check it for myself.
Old 05-07-2004, 06:01 PM
jroehl's Avatar
jroehl
jroehl is offline
It can make a world of difference. The gap range is usually about 10% of the gap, and I always set it to the LOW end of the gap, I've found that the engine typically runs better that way. The voltage required to jump a given gap is a linear function, so a 10% increase in gap size requires 10% more voltage to jump the gap. But you should have plenty of voltage to spare if your ignition system is in working order. And, as the plugs wear, that gap opens up (albeit very slowly), so you may as well start on the low end of the range.
Jason
dobenator
12-06-2016 12:06 PM
Trevor1
12-07-2006 11:32 PM
EXPLORER GUY
12-01-2006 10:49 AM
ssKable
03-05-2005 12:46 PM
elstx
16
09-18-2003 05:17 PM
Quick Reply: Spark Plug Gap
