Spark Plug Gap
Old May 7, 2004 | 11:33 AM
bent rim's Avatar
bent rim
Spark Plug Gap
Just wondering how critical gapping new plugs are vs installing straight out of the box in regards to power and mpg's.
Old May 7, 2004 | 11:49 AM
MustangGT221's Avatar
MustangGT221
Very, you need the correct gap.
Old May 7, 2004 | 01:06 PM
acerockola77's Avatar
acerockola77
Most of the time the plugs that I get already are set to the correct gap (well the specified gap for the truck).
Old May 7, 2004 | 01:16 PM
Slade901's Avatar
Slade901
I used to take the word of part clerk and telling me that it is already gapped to the right specs for my vehicle.
One day I checked the gap just to make sure and not all of them have the same gap and I have to adjust it myself.
Everytime I order spark plugs, I always tell them to write the gap specs on the side of the spark plug box and check it for myself.
Old May 7, 2004 | 06:01 PM
jroehl's Avatar
jroehl
It can make a world of difference. The gap range is usually about 10% of the gap, and I always set it to the LOW end of the gap, I've found that the engine typically runs better that way. The voltage required to jump a given gap is a linear function, so a 10% increase in gap size requires 10% more voltage to jump the gap. But you should have plenty of voltage to spare if your ignition system is in working order. And, as the plugs wear, that gap opens up (albeit very slowly), so you may as well start on the low end of the range.
Jason
dobenator
Dec 6, 2016 12:06 PM
Trevor1
Dec 7, 2006 11:32 PM
EXPLORER GUY
Dec 1, 2006 10:49 AM
ssKable
Mar 5, 2005 12:46 PM
elstx
16
Sep 18, 2003 05:17 PM
