Tire Air Presure
Originally Posted by Hossy
Well i would hope you lube steering componets! And my tires wear just fine with 15 psi in them. And your swampers are still under inflated per interco's recommendations for maximum carrying capacity, 75 psi is max. And all radial tires bulge. Aren't super swampers a bias-ply tire? Maybe not cant remember. Look we could go on with this forever, and the point is, load carrying capacity of a tire has everything to with max air pressure for max wieght, not necessarily tire wear. Thats a fact!!
Hossy you are missing the whole point of why Utah Jake started this tread. He wanted to know what tire pressure he should be running his tires at not what tire pressure he should be running when the truck has a load in it. And just because you have a load in your truck does not mean that you should be running the maximum air pressure of the tire.
Outside of wheeling the proper tire pressure you should be running is that which will give "even" pressure across the whole contact patch of the tire. This is how it was explained to me by a Michelin tire tech that was here from Europe working an SCCA Pro Rally event in PA. They use an infrared pyrometer to measure the temperature of the tire across the contact patch at various points from shoulder to shoulder (sound familiar). What he is looking for is a consistent temperature reading which indicates proper inflation. If the temperature readings are higher at the crown of the tire, it is overinflated. If the temperatures are higher at the shoulders, the tire is under-inflated. Either condition is dangerous as you are fatiguing the tire by entering too much heat in a concentrated part of the tire. The infrared pyrometer is the most accurate way to determine proper inflation and they use it for all their tire testing. Car, light truck, OTR, heavy equipment, military, racing car and racing truck tires. I made the comment about the chalk method and he said that is still an effective way of determining tire pressure just not as high tech.
How many miles do you get out of your swampers ronin007? Looking to go more aggressive when my 305's wear out! Thanks.
For what its worth, daily driving I'm running 60 psi front/rear with canopy. I've tried down to 55, but that felt too soft; as did dropping the rear independent of the front. So far, 60/60 seems the best, and I'll monitor tire wear and adjust accordingly.
hardwaterfreak
12-22-2011 07:56 PM
