Aerostar Ford Aerostar
93 4x4 Aerostar Starter Replacement Question
Old 04-23-2004, 02:19 PM
jimguns's Avatar
jimguns
jimguns is offline
Does anyone know where to place a jack under the engine so I can replace the starter on my 1993 Ford Aerostar? I have looked up info in books, but only find out information regarding 2wd. I have loosen the moter mount on the left side, but do not know where to place the jack. I do not want to place it under the aluminum casing. Any suggestions? Thanks, Jimguns@aol.com
Old 04-23-2004, 02:30 PM
BarryFS's Avatar
BarryFS
BarryFS is offline
Are you replacing the starter jimguns? I don't think loosening the motor mounts is the way to go. I changed mine last month,('91 4L 4x4), I jacked up the front left corner suspension, and unbolted the front drive shaft at the rear end, and it just slipped through. Getting the cables on and off is not easy, there was no slack. I discovered that what passes as a frame in that area, crumples if you jack it.
Old 04-23-2004, 07:23 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
just disconnect front driveshaft from axle
Old 04-24-2004, 11:42 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
mwkobe's got it right. I just did this about a month ago. It may not look like it, but there is enough room to get the starter out.
Old 04-25-2004, 10:11 AM
Steeve D's Avatar
Steeve D
Steeve D is offline
I thing i have to change my starter too...When i try to start my aerostar 1991 4x4 i hear on ly a TOC one time.
i change my selenoid and make no difefrence.
My question is Where exactly is my starter...i had before a 2x4 aerostar and he was visible..
but that one i check and i did't found it .
He's he on the driver side or passenger side???? and near from what.
thanks
Steeve
Old 04-25-2004, 10:38 AM
mwkobe's Avatar
mwkobe
mwkobe is offline
driverside near front drive shaft
Old 04-25-2004, 10:45 AM
Steeve D's Avatar
Steeve D
Steeve D is offline
thank you i go there and check it.
thanks again
Steeve
Old 04-25-2004, 11:20 AM
Steeve D's Avatar
Steeve D
Steeve D is offline
i found it..thanks....it was dirty ...that's why i did't found it the first time.
appreciate your help....that my problem i will try to change it by myself.
Steeve
Old 04-26-2004, 03:34 PM
countrydude's Avatar
countrydude
countrydude is offline
replacing starter
I have had trouble replacing the starter, which I removed the bolts, but the drive shaft in interfering with it, I have removed the 4 bolts for the drive shaft, but it's not moving, any help would be greatly appreciated.
Old 04-26-2004, 04:20 PM
BarryFS's Avatar
BarryFS
BarryFS is offline
Which engine to you have there countrydude?
Old 04-26-2004, 04:23 PM
countrydude
4 litre
I have a 4 litre engine
Old 04-26-2004, 04:27 PM
mwkobe's Avatar
mwkobe
mwkobe is offline
the splines on the driveshaft are stuck in the transfer case u need to pry or hameer the driveshaft bask toward the transfer case
Old 04-26-2004, 04:30 PM
BarryFS's Avatar
BarryFS
BarryFS is offline
When I did that job (91 AWD 4L) there was enough room with the shaft pushed to one side to squeeze the starter through with about quarter inch clearance. I did rotate the starter a bit to get it out. It should go through.
countrydude
this seems to be getting harder & harder for a do it yourselfer...lol....thanks and I will keep trying
Old 04-26-2004, 04:35 PM
countrydude
I have tried to hit the drive shaft, but with no luck in moving it apart at the front, I know if i get it off, then I can get the starter out (with little space). is there a way to seperate the drive shaft after the bolts are removed?
Quick Reply: 93 4x4 Aerostar Starter Replacement Question
