Ball Joint Question
Ball Joint Question
Hey, anybody out there had any ball joint problems with your Superduty? I have an 01 4wd with 47k on it and the upper ball joint on the left side is giving up. I do a little off roading but nothing too crazy. Bottom line is I assume I should replace upper and lower on both sides rather than just replace the one with obvious problems. Any advice is appreciated.
MJC
MJC
Fairly common problem, though usually you get a few more miles out of them.
Due to your relatively low miles, I'd just do the one bad side, upper and lower. It's a fairly expensive and time consuming fix, so for my money, I'd wait to see some problems on the good side before I went ahead.
Waxy
Waxy
MClark77
I am going through this same problem right now (01 4wd F350 62k miles)
All four ball joints toast and drivers side hub. I changed the hub tonight. I have got all the ball joints and the hub but I have not received the ball joint press yet and I wanted to get the truck back on the road. I will do the ball joints and the pass side hub this weekend. I am changing both hubs as I believe if one fails then the other is not far behind. The next weekend I will do drivers side ball joints.
I think you should change both on that one side as you have it apart already. The hub was no sweat. 1 1/2 hours at best.
Anyone who replaces A hub, make sure you you get new studs, and nuts, as getting the old studs out was A pain. If I had gotten new studs I would have been done in an hour.
I posted A thread titled "ball joints and hub" and someone replyed with step by step on changing the ball joints. Very helpful article. I went and bought a repair manual and the reply that was posted was better than the book.
Good luck with the project and I hope you only need to do one side.
Ugh, I think I'm in the same boat! Just started today, LOUD popping & creaking coming from left front wheel area. Only happens when turning or breaking. I did a LOT of deep water crossings this last weekend with all the rain we had, I think I finally did my ball joints & bearings in for good!
I just had mine replaced yesterday at 12K. I took it in just before I rolled 12K to have an alignment check under warranty. The tech took it on a test drive and said it was possibly binding, hard to steer and not recentering as it should. All that was news to me. But, at no cost, they replaced all 4 ball joints the same day and adjusted the steering mesh. They refered to TSB 01-3-2 for the problem. At least that's what it says on my invoice. Even though I didn't recognize the problem before, it does steer much easier now. So I guess it is a common problem.
