Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-14-2004, 06:07 PM
scotauto is starting off with a positive reputation.
Smile Engine without a casting number identification
I'VE RECENTLY AQUIRRED A RANCHERO FROM 1973 AND WAS WONDERING IF THERE ARE ANY WAYS TO IDENTIFY THE ENGINE WITHOUT CHECKING THE STROKE AND BORE ETC. i CANNOT FIND ANY CASTING NUMBER ON THE BLOCK (ABOVE THE STARTER) .cAN IT BE SEEN WITH THE STARTER AND EXHAUST MANIFOLDS IN PLACE? i HAVE NOTED THAT THERE IS AN INTAKE MANIFOLD FOR A 302(I THINK). dOES THIS FIT ON A 351 ALSO? i'VE ALSO MATCHED BOUGHT SOME SPARK PLUGS FOR THE ENGINE AND MY SUPPLIER ASSURED ME THAT IF IT HAD THE "LARGE SIZE" PLUGS IT WAS DEFINETELY NOT A 302, BUT PROBABLY A 351. hOWEVER THE SMALL TELL TALE SIGNS i CAN SEE LEAD ME TO BELIEVE IT IS A 302. i WOULD LIKE TO BE PROVED WRONG AND FIND IT IS SOMETHING BIGGER!!
  #2 (permalink)
Old 04-14-2004, 11:42 PM
grclark351 is starting off with a positive reputation.
you might have to drop the starter to see the numbers. i think all the W(windsor) style engines used the huge(18mm?) plugs, about the size of a thumb. this would include 289, 302 and 351w. do some investigating of the firing order, this may help single out which engine you have, and/or drop the starter.
__________________
http://www.supermotors.net/vehicles/registry/10950
http://www.supermotors.net/vehicles/registry/10952
http://www.supermotors.net/vehicles/registry/16826
  #3 (permalink)
Old 04-15-2004, 02:42 PM
DRopped the starter and under all the mud found D4DE-6015-AA then under it 3J17. I have looked up that the engine is a 302, but what does the 3J17 stand for?
  #4 (permalink)
Old 04-15-2004, 10:52 PM
it's a date code. i think it says december 17 of '73, the 3 being the year of the decade, the j being december and the 17th.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
