Transmission cooler
Transmission cooler
while my truck is down for fuel troubles, I ended up changeing the transmission filter and fluid. How much extra Mercon do I need to put in when there is a transmission cooler? I alread put in the 4 and 1/2 qts that the book says to put. I think what I will do is to add the fluid as needed when I do get the thing running. Beings that the engine needs to be running and up to temp when the fluid is checked.
I will add a little extra fluid. I only added 4 qts when I put the fluid. I bought 7 qts and I have 3 unopened sitting in the front seat. I figure that if I add a 5th that it will not over fill it.
But on the other hand, I might as well wait tillI get it up and running again and check and add the fluid the proper way, while the engine is running.
