Any performance gain from 390 heads with 16 bolt exhaust?
I have a 390 that I am going to rebuild soon and have located another set of heads with the 16 bolt exaust manifold pattern. The owner says they are from a 390 GT engine and are rebuilt. They look good and he wants $400. The heads are more money than I had planned on putting into the heads I have so it would add to the cost. Are these heads worth messing for $400 to gain any performance over plain 390 heads.
I have not looked at the heads close enough to get the numbers off of them. I'll get them and post them later. They do have the 16 bolt pattern on the exhaust the same as pictured on the top. So, these heads could be the CJ heads if someone hasn't added the extra bolt holes? Can the other bolt holes be added to the GT heads to appear factory?
Casting # is your best bet. A GT head can't be made to look like a CJ head. Check out the upper bolt holes, the CJ has them all in the same plane while the GT has the end ones lowered.
Also notice the height of the ports, the GT has lower ports compared to the CJ. Use the diagonal bolt holes as a reference. On the CJ the floor of the port lines up with the top of the bolt hole and on the GT the floor lines up with the bottom of the same bolt hole.
cmbroo1
59
08-12-2018 07:44 PM
northdakota 67ford
12-16-2015 02:19 PM
Randyb12
08-24-2003 06:11 PM
