Fog Light Wiring???
Fog Light Wiring???
Does anyone know if fog light wiring is a standard installation for the F-series SD pickups???
My 350SD 2000'172" 6-wheel light control pulls out when the switch is rotated to the "on" position. I would like to connect aftermarket fog lamps to this switch.
Any suggestions????
Any suggestions????
Fog Light Wiring???
According to an earlier notification on this board, the switch currently installed in the SD will not support turning on foglights. You will need to order the foglight kit from Ford, which includes Hella foglights, to get the correct switch that will turn on the forlights. The switch is direct replacement for the one already installed, but it has the connections internal to turn on the fogs that is not present in the on that comes initially from the factory.
