MAX Tire size for lowered 53-56
Originally Posted by GreatNorthWoods
'fenders,
Guess I wasn't too clear on my statement. What I mean is that if you compare a 75 series tire to a 50/60 series and both are the same height, the 75 will have a higher profile (the distance between the rim and the ground) than the 60 series and therefore will have a softer ride. In your real world example, you would have to find a 75 series tire that was 28 inches tall (if you are limited to 28 inches). I have no access to a tire chart so I can't say for sure what size that would be, but if I had to guess I'd say a 225:75 would be close, possibly even a 215-75. Does that make more sense?
Vern
Vern
But back to the thread subject. I brought home some 275-60s last night hoping I could run them. I really like the look. They clear OK on the inside but they would definitely rub the fender lip before my suspension stops. I would be unable to lower my ride height ever so I may exchange them today. I need to do some measuring first on my running board to cab gap to make sure my bed is located correctly. If it needs to come up at all I would probably be OK. But just barely.
I really love the look of the magazine trucks with big rubber stuffed up into the rear wheelwells, but that just can't happen with stock steel fenders and no wheel tubs.
Originally Posted by tmyers
Joners, did you narrow the rear end and if so how much.
What do you mean, rear end, frame wise or differential wise?
Frame wasnt touched, only mods to it is that it's boxed. The diff was custom from Moser, so I just ordered it to length.
Originally Posted by 51dueller
A little off topic but we have some old L60-15 tires and I was wondering what size rim you would need you use them. I have 15x7.5 rims.
Almost sure that's the P-metric equivalent to a 275-60. Same size I just returned. BFG recommends 7-9.5" rim. I would say about 8-8.5 is optimum. But 7.5 will work.
If I remember correctly, the rear fender is only 11" from bed side mounting flange to inner wheel well lip. This equates to roughly 275 mm which means a 275 cross-section would fit with no clearance on either side and a wheel of perfect backspacing. I'm not sure if a half inch clearance on each side is enough especially if there is any lateral movement of the axle with respect to the frame but this suggests a maximum of 10" cross-section or 255 mm. There are 3" wider rear fenders available which would then allow a 2 to 3" wider tire.
The above is based on my memory being correct which is certainly not always the case. Just my thoughts.
All you say above is fact. Only variable is manufacturer advertised sizes are approximate. BF Goodrick 255 does not = Cooper or Goodyear 255. Heck, even BF Goodrich missed on the advertised tire height by almost an inch and I did use the specified rim they supposedly calculated at. That's why I took a shot on the 275s. Then 255s are installed now and I have my suspension travel back so I can haul small loads in the truck.
BTW, remember the No Limit drop shackles we surmised at PF could not possibly drop the rear 2 inches when only one end of spring is raised 2". Well surprise, surprise. It yielded a 1 inch drop. Not a deal cause I knew that before I bought the shackles. If you raise the front spring mount location too, you can get the other inch, but the instructions advertise 4 inches if you do both ends. That's not possible without jacking with the leaves.
You know that loss of memory is a sure sign of Viagra addiction. Ok back to the topic. Have any of you run a 16" wheel with a lower profile tire? Is the ride worse with leaf springs then if you use the 4 bar setup? Now did I forget anything? Ed
Ed
A 16 is exactly what I wish I had done. You could get inside the rear wheel well with a 60 or 65 series tire. Real low profile will not enhance your ride quality. I'd avoid huge rims on a daily driver.
Most of the vendors have told me your ride will almost always be a little better with leaf springs. But a set of bars can be respectable too if set up properly with the right springs. Setup is the key of course. You can screw up the ride with leaf springs if you alter them enough.
Ed
firstrider
16
04-19-2017 05:43 PM
davidmoss1992
16
05-01-2012 10:35 PM
jcloud
07-12-2010 06:37 PM
