97 powerstroke injection or turbo problem
My 97 F350 Powerstroke has started to loose boost and blow raw fuel out the tail pipe at about 2200 RPM. When I get up to about 3000 RPM plus it seems to go away. But when I got down the through the RPMs it does it again. I've had two mechanics look at it but they aren't seeing a fall off in the boost. I replaced one bad injector but the rest seem to work fine. It seems like a computer problem or a sensor feeding data to the computer. Have you heard of this problem before?
Thank you for your response. It happens during acceleration and acts as though it has lost boost until about 3000 RPM then turbo seens to kick in again. The mechanic had a boost valve on it to test and saw no fall off in the boost. Two diesel mechanics have thrown up their hands in frustration.
Lignite
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
16
12-21-2009 04:13 PM
J-Rod76
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
04-21-2004 08:59 PM
