Having problems locating a right side headlight bucket for a 1972 F-100. Dennis Carpentar lists them but does carry the one for a 1972. Any suggestions on where to find one?
Just to make sure we're on the same wavelength here...typically a 'headlight bucket' is the small metal bowl that the headlight sits in and is connected to via springs and adjustment screws. The 'headlight door' or 'headlight bezel' is the steel or aluminum trim that surrounds the headlight. Which one are you talking about? AFAIK the headlight buckets (as I'm describing them here) are the same.
I put a 70-72 style grille shell on my 69 and the headlight buckets from the 69 fit perfectly so I am going to say that any of the 67-72 headlight buckets will work.
