51 transmission help-starts in gear
Hello all. Just got engine installed after swapping out with a running replacement. On start up (driveshaft disconnected) the transmission is already in gear, can't shift while running. Opened cover plate above stick and can observe throw out bearing moving about as far as it can go, pressur eplate fingers, but disc is far back towards flywheel. Seems to be engaged and won't release. Any help/clues appreciated. 226 flathead
Thanks, removed trans today and pressure plate. Some slight rust, but it looks to me that the pressur eplate is too thick or the fingers not long or deep enough to ever reach the plate. The disc has 2 sides. one raised. With the raised side in the plate it still seems way to far from the fingers. The throw out bearing will only move a 1-2 inches and the fingers come no where near touching disc. What do you think?
I would try to get a new disc and pressure plate if you can. Also clean all the rust off the flywheel. Make sure you have the disc facing right direction. Also replace t. o. bearing if you can afford it. If the flywheel is all checked or small spider type cracks, get it turned. Do it while it's apart to avoid headaches later.
Barry
50 F-1
Barry
50 F-1
Yes, raised side to pressure plate. Take the T.O. bearing and put your finger thru the center and spin the bearing. If you hear any type of noise or rattling, replace it. If it seems loose, replace. Make sure you put some lube on the collar on the tranny for the bearing and some on the splined front input shaft so nothing will rust up and stick.
Barry
Barry
The fingers won't reach the disc. They only release the steel plate in pressure plate to allow disc to move a little. In other word the pressure plate sandwiches the disc between it and the flywheel and when you push in on throw out bearing it moves the steel plate in pressure plate enough to release that pressure to allow disc to slip between the flywheel and pressure plate while changing gears.
hanks for correcting me, I had the concept backwards but the results are the same, no disc freeplay, therefore the space between plate and flywheel is to tight? I conclude 2 possibilities or both, surfaces need cleaning or pressure plate is out of spec. Well I'm looking to replace the pressure plate rather than risk reassembly and teardown again, and there was a little surface rust on the flywheel. Thanks!
