Propane injection
Propane injection
Is there anyone out there using Propane injection on there PSD??
I have been doing allot of reading on this subject and wondering if it's all that and a bag of chip's???...
If you do have one what brand?? And what did it do for you?? ie; better performance, mileage or both or what happened??
Do you recommend one???
Joe
P.S.
I would also like to say thank you to the people of this web site, as I have learned a lot from the great people on this site.. Please keep up the good work.
Joe
P.S.
They're great, if used carefully. Used carelessly, they can destroy your engine. There are ways to safeguard against damage though. If you're serious about looking into it, I'd be glad to help you get started on the right foot.
Scott.
I have an old power shot system that I improved upon. I can spray up to 3 nozzles at once.
1 is for economy
2 is for towing
All 3 are for smoking anything.
My mileage goes up about 2mpg if I can keep my foot out of it.
I've been running it for over 5 years and over 150K it's a lot of fun but you need to be careful if you have powder metal rods.
I live in Ca.
GENE
1 is for economy
2 is for towing
I live in Ca.
GENE
As WeWeld stated, he gets a 2mpg increase if he keeps his foot out of it. I guess he's just got more self-discipline than I do. He's also got one of the original Powershot systems, if his is 5 years old. The newer ones, (mine is only one year old), have been detuned to prevent damage to the engine, but in so doing, they've reduced the amount that the system can flow. I've modified mine to maximize flow, but that's just the kind of guy I am.
If you were to get a system, and could control your self, you'd likely see an improvement, especially when towing.
I live in the Seattle area.
I should be getting my system today!!! Quad has me all jazzed up to get it installed and going. I'm going with the Bully Dog system just because I'm getting a heck of a deal on a used system, otherwise I'd go with the Powershot 2000 becuase of all the good things I've heard about it. I can't wait!!! Thanks a lot Quad for the previous advice!!
propane injection
My son has modified his service truck to propane boost. He is in the Army over in Iraq and it is a 1 1/2 ton. He removed the cold weather start ether injection setup and put the propane in there with a switch operated valve. He said only problem was if you stayed at full throttle too long the turbo exhaust would get really hot. He installed it for when you need to change locations in a hurry and he said you wouldn't believe the acceleration you get with it.
Actually, making power with propane is a little cooer than doing it with diesel fuel alone. For example, if a stock truck makes 190 rwhp, doing that with a mixture of propane and diesel will be cooler than doing it with straight diesel. However, with propane, you're capable of making a lot more hp, so doing that makes the truck run hotter. If I'm blasting up the 12% test hill, my speedo, tach, boost gauge, and pyro swing from left to right in unison, like the Rockettes.
So, you apparently know a little about Kent.... Actually, no, it's a new road they've put in about a year ago that runs up the East Hill. It's 277th Street, and cuts up the hill directly beside the drive-in theater on Auburn Way. It dumps you out on Kent-Kangley at 116th, if you're familar with that area.
Mike- If you decide to run the hill, here's the deal: From Auburn Way North, head up the hill. At the base of the hill, there's a 50mph Speed Limit sign, (Yeah, right!) Hit that sign at 60mph in OD, and bury your foot. See how fast you're going when you hit the top of the hill. I consistently hit 80mph.
I generally have to pick the Camry's out of my grill when I get home, though.
Hit the bottom of the hill at about 55 (traffic). Managed 70 by mid way up but couldn't get anymore - just held 70. BTW, there was a Camry next to me :-)
Your mods must be doing something good!
mike
Alrighty, thought i'd throw a curveball in there for you guys to think about. This last fall, a buddy that pulls with an 02' duramax installed a homemade propane setup. And it was probably the last pull we went to last year when he finally got it installed. me n' him were talking before the pull and wondered what effect mapp gas would have (50% acetelyne/ 50% propane)... and WOW it made that little chevy scream. The only detrimental attribue the the mapp however, was that it made the egts jump.
