4.6 Upgrades or are they?
Old 02-26-2004, 03:41 AM
krunker's Avatar
krunker
krunker is offline
I have a 97 f-150. I had a chip, 3" flow pro cat back, gibson headers and a K&N FIPK. I just put on a 75mm BBK throttle body and a motorvator TBS. Seems that up until 2500 rpms it dogs but after its snaps your head back. Any one have any idea where all of my low end went?
Old 02-26-2004, 09:04 AM
jejenkins's Avatar
jejenkins
jejenkins is offline
Low End
I suspect it was in the headers. Some headers are for more top end for the engine.
It is important to get headers tuned for what you want. A fast powerful car would probably want top end.
A truck or suv will probably want low end torque. Its all in the header diameter and tuning or the way they are bent and shaped.
Old 02-26-2004, 05:27 PM
krunker's Avatar
krunker
krunker is offline
Your right in that I did lose some low end when I put the headers on, but when I installed the throttle body and spacer I made it way worse.
Old 02-26-2004, 09:37 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
The TPS may be out of adjustment causing a delay in fuel and timing advance.
Old 02-27-2004, 02:52 AM
krunker's Avatar
krunker
krunker is offline
Is there anyway for me to adjust the throttle position sensor or is that something that a dealer would have to do?
Old 02-28-2004, 07:25 PM
JustinH's Avatar
JustinH
JustinH is offline
Headers on a stock 97 aren't going to get you much.
The cheap way to make these fast is install a PI intake, and PI cams, with a tune you should be very close to what the PI motors make, and remember you don't have pi heads yet.
After you uncork the intake, and get the heads fully ported, then you can move onto headers, and get some big NA power.
JH
Old 02-29-2004, 10:36 PM
krunker's Avatar
krunker
krunker is offline
I'll see if I can't locate those parts. Thanx.
