difference between 4.6 and 5.4
Old 02-25-2004, 10:54 PM
CPerry's Avatar
CPerry
CPerry is offline
I know they have the same bore, are the cylinders taller on the 5.4 or do they share the same cylinders?
Old 02-26-2004, 04:00 AM
krunker's Avatar
krunker
krunker is offline
Granted I'm no expert, but assuming the bore is the same that means the stroke would have to be longer meaning that the 5.4 would have longer connecting rods and a larger crank.
Old 02-26-2004, 01:20 PM
mantta's Avatar
mantta
mantta is offline
Krunker, don't you mean shorter connecting rods and a longer stroke on the crank?
Old 02-26-2004, 01:59 PM
CPerry's Avatar
CPerry
CPerry is offline
I realize it would need a longer stroke but do they share the same cylinders or are the 5.4's taller?
Old 02-26-2004, 05:33 PM
krunker's Avatar
krunker
krunker is offline
Ya, that sounds more like it, although I think the 5.4 is also a little taller and wider. I have the manual for 1997 and newer F-150's, I'll consult it and report back. Also, when you ask if they share the same cylinders, do you actually mean pistons or the actual liners in the block?
Old 02-26-2004, 09:30 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
The 5.4L block is taller to accomodate the longer stroke. They have the same bore.
The stroke on the 5.4L is 4.14". The block is taller and wider so the intakes will not interchange. The bolt on accesories in the front will interchange. The heads are the same as well as the camshafts.
If you are looking to upgrade from a 4.6L to a 5.4L, check out Ford's new 5.0L Modular engine with a redesigned block for a larger bore with 4.6L stroke.
Jimmy
Old 09-03-2020, 05:44 PM
flyboy40461's Avatar
flyboy40461
flyboy40461 is offline
Difference between 5.4 and 4.9 motor
I have a 04 150 5.4 FX4 and have the option to buy a 04 4 wheel drive with the smaller motor but bad transmission.. my question: will the auto transmission in my truck (75) work with the smaller motor?
PoeSG1
1997 - 2003 F150
02-01-2017 01:23 AM
Luckett35
Modular V8 (4.6L, 5.4L)
07-28-2016 05:36 PM
PROBIKE101
05-14-2016 09:21 PM
tgreen6803
03-11-2016 10:32 AM
megjosh1
03-11-2009 09:09 AM
Quick Reply: difference between 4.6 and 5.4
