HELP! Driver's door won't open, 98 explorer
I need help. My girlfriend has a 98 Ford Explorer sport. The driver's door will not unlock, thus we can't get it open. The key, remote entry fob, and the inside unlock switch will not unlock the door. I saw on another site that it is possibly the linkage or a rod or something. I have a feeling I can repair it if I can get the door open and the door panel off. Problem is, I can't find a way to open the door. We even tried to pull the door lock stem (or whatever you call it) up, but it will not move. The local ford dealership wants 300 dollars to fix it. I am tired of my girlfriend having to enter the vehicle from the passenger's side and then climb over the armrest to drive. I'm thinking about just ripping into the door panel from the inside without opening the door, but then I'll have to get a new door panel. I don't want to do this. Anybody run into this before or have any ideas? Thanks for any help/advice.
when you say the key wont open the door, is the key able to turn and it wont open or will the key not turn at all? reason why i ask, my key sometimes wont turn when i try to unlock manually, i have to wiggle it a few times and work it left and right. about a yr ago i took the tumbler out to check why it wouldnt open and what i found was the casing was binding causing the pins in the key way to stick, i sprayed a bunch of lithium grease into the keyway and while in a vise inserted the key and turned it left and right. worked out pretty good, every now and then i spray some lithium grease into the keyway to keep everything moving. anyway, the lock should move up manually with the way i've described below and what your problem is is the lock acuator, mine when out about a yr ago, had to get it from ford for about $65(i think). the acuator is rivited(just one) to the door just below the latch. i just replaced the rivit with a sheet metal bolt a nut and lock washer. its a fairly easy do it yourself, just follow the rod that is attached to the door lock down to the acuator remove the screws that hold the latch disconnect the harnesses from all the connectors, knock the rivit out and your good to go. well i hope this helps.....good luck
drill with a very fine drill bit on top of the lock **** then screw a small enough screw into the ****, then you can try to pull the lock up that way.
[i]
drill with a very fine drill bit on top of the lock **** then screw a small enough screw into the ****, then you can try to pull the lock up that way. [/B]
kfowler.98
02-24-2017 03:05 PM
toddrochester
28
01-20-2012 06:33 PM
kev100
02-18-2011 07:30 PM
