Spark plug blew out of head
I had my spark plugs changed 4 months and about 10,000 miles ago. Today a spark plug blew out of the head on the driver side. I tried to put it back in and it seems like the guy who put it in stripped the head. I can screw it in about one and a half revolutions finger tight and then it won't turn any more. It does have the coil on plug ignition (99 F150 5.4). I was using a long spark plug socket with a swivel to try to screw it in. The place that did the work is no longer in business. How bad am I screwed? Is there any was this can be fixed without replacing the heads? Any ideas how much this is going to cost to fix?
Thanks
Thanks
Yup, same thing happened to my 99 F-150 5.4
Blew a plug and it stripped the threads on the way out. I did a thread insert (welded an extention to the tap cuz the kit required a socket to big in diameter to fit in the plug hole) and so far it's been working fine......been about 3 months now. Kit was like 30 bucks or so.
http://www.timesert.com/
I had mis-spelled it earlier sorry,...It seems to be what most repair shops and dealers are using now. It seems to handle the pressure a bit better than your standard issue Heli-coil. I hope this helps.
My father has worked for a Ford dealer in northern Wisconsin for the past 3 years and my neibor was a Ford tech for the past 10 years and neither of them has ever seen a truck come in with this problem, so I dont think its a major issue.
I think it happens when people try to change the plugs without letting the engine cool competely and/or they crossthread the plugs when they install them.
My brother has over 100,000 miles on his '99 F-250 with a V10 and Ive got almost 140,000 miles on my '99 F-150 with a 5.4L and neither of us has popped a plug yet (knock on wood).
