Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-17-2004, 10:55 PM
chillybone is starting off with a positive reputation.
Hesitation after engine warms up
I have a 99 F150 with the 5.4L, 50000 mi. The truck seems to bog down when under a med. to hard acceleration, then catches up and runs fine. It seems to only happen after it has warmed up to mormal temp. Checked plugs, changed fuel filter, everything looked good. Tranny fluid changed at 40000. I also have not had the check engine light on at all.
???Anyone have any ideas???
  #2 (permalink)
Old 02-18-2004, 12:07 AM
BrianA's Avatar
BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE. BrianA has a very good reputation on FTE.
Chillybone,
Welcome to FTE! Glad you found us and hope we can help.
I only have a guess....fuel pump. I have heard of a few failing but I have never had the problem. Maybe fuel injectors.
Somebody will probably come along that will have a better idea.
Again, welcome to FTE.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #3 (permalink)
Old 02-18-2004, 12:32 PM
LxMan1's Avatar
LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold LxMan1 is a splendid one to behold
Try cleaning the mass-airflow sensor. When they get dirty, they tend to lean out the engine.
Jimmy
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #4 (permalink)
Old 02-18-2004, 06:30 PM
abarreto is starting off with a positive reputation.
I will sugest to find a good scanner like Autoxray 6000 and look for operating conditions after warm up. I have found that sometimes marginal oxygen sensors, air flow meter, etc. can cause operating malfunction without activating the check engine light.
Good Luck!
Ponsik
  #5 (permalink)
Old 02-20-2004, 02:44 AM
hood's Avatar
hood is starting off with a positive reputation.
chillybone:
How's that air filter looking? Or more like, when was that air filter last changed???
-hooD
__________________
2002 F-150 4X4 7700 (5.4L)
1998 Sable (3.0L)
1996 Cougar (4.6L)
POWERED BY FORD!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
