TT Mirrors
TT Mirrors
I just bought a set of power TT mirrors for my '00 SD EC 4x4 and the instructions showed that I have to take off the door panel to get at the wires located behind the speaker.
I scrolled the oodles of pages in our forum and found differing advice on whether the door panel has to come off.
HELP PLEASE !!!! If anyone can give me detailed directions, my wife would very grateful, otherwise she will have to do without an anniversary present cuz I spent the money at the FORD garage having them install them. And you know how that always turns out...
Thanks
Thanks
TT Mirrors
i just put mine on today.... you have to remove the door panel and the speaker to get to the wire. it is not behind the speaker, but the sound material is covered partly by the speaker.... you may be able to get to it without removing the speaker... but better to be safe and spend the extra two minutes.
TT Mirrors
Did mine awhile ago but as I remember, Pop that black trim piece off at corner above door panel,it just clips on.
To remove door panel remove window switches they also pop out, remove screw,remove marker light lens remove screw unplug light plug then you just lift straight up on the panel .
You will have to remove the speaker and unplug it to get to the mirror wires and plug.
Hope this helps, it took me about 30 min to install both.
twinbulls
twinbulls
TT Mirrors
I changed to the TT mirrors in December. The instructions seemed very long. Once I got started they were very easy to follow. Go ahead and take the panels off; its just a few screws and clips for the panels and 4 screws for the speakers. this way you wll have full access to the wire connectors. I did not use the extra pigtails supplied. Both mirrors can be done in less than an hour.
